Rear cylinder is #1. Is it?
OK have the engine bottom put together. All looks good but acordingto alignment on cams and timing It seems like # 1 cylinder is the rear?????????
Cams timing marks are set at 3 and 9 o-clock. The cam and crank timing marks are at 6 and 12. BUT My crank pin is at rear cylinder TDC. Is the #1 cylinder relative to rotation of engine(rear cylinder is #1), or is it relative to the forward cylinder(#1 is front)?
I beleve it should be the rear cylinder is number one. In other words the direction the crank is rotating the rear cylinder fires first.
section8joe
03-31-2014 01:10 PM
