Dyno and new Screamin' EagleŽ Heavy Breather Performance Air Cleaner Kit
I have already had my 09 Ultra Classic Dynoed with a Stage 1 SE air cleaner. I'm going to install a new Screamin' EagleŽ Heavy Breather Performance Air Cleaner Kit and want to know if I need to have it Dynoed again. I have a Rinehart exhaust system. Of course the dealership says yes $$$$, but what can I expect if I dont?
It's installed and the bike runs great. I found I needed the breather bolts that were normally OE, but not on my 09 Ultra. And I guess the Chinese have bad days as one of the a@@holes put a chrome trim ring for a Sportster in a touring kit. Acceleration is quicker, especially on the highways, with 60 to 80 in a blink. Someday I will get it on the Dyno again, after I finish getting all the little extras. Now if it will only stop raining.....
Wrong Instructions For Heavy Breather Install
Bought a Heavy Breather for my 2011 Ultra CVO RG, the instructions stated that models 2008 and up you can use the O.E. breather bolts. After installing and running the bike it began to run bad, it was building crankcase pressure. I went to the dealer and they new right away what it was because they got burned on looking at the directions when they started putting them on. Ends up their was a revision later stating that you must purchase different breather bolts. So be careful when purchasing a heavy breather you dont get screwed over like I did, you MUST buy breather bolts for all models exept an XL.
