110 head mod - Harley Davidson Forums
110 head mod
P
Thread Tools Search this Thread
Old 09-30-2011, 02:02 PM
bumper57 bumper57 is offline
New Member
Default 110 head mod
I just picked up a set of se cvo 110 heads. I've read that you can only cut them .030 before you get into the automatic comp release my question is can I weld the release hole up and cut them enough to bring the cc's to 88'' stock volume?
Old 09-30-2011, 02:29 PM
djl's Avatar
djl djl is online now
Quote:
What's the PN on the heads? Reason I ask is there was a batch of those heads that had problems; loose guides and some other **** I can't recall right now. They have been floating around on Ebay for a while, real cheap.
Why not get a plug for the ACRs instead of welding and heating up the heads and perhaps loosening up a vlave seat or guide? IMHO, it would be better to look at a dome piston to get the compression right; if that is your goal.
From what I understand, those heads can be made to work well but if they are among the poor quality batch, new guides are in order.
Old 09-30-2011, 04:34 PM
BadBagger08's Avatar
BadBagger08 BadBagger08 is offline
Senior Rider
Even if you plug the ACR. you can't bring the cc down enough to work with a flat top and get decent comp. There is a few issues that a local indy could fix at not much of a cost. these heads need they're guides replaced with some quality bronze guides and a new valve job, some new springs and they're good to go.
You can pick up a SE 103 10.5:1 piston for about 250.00 made for these heads.
Old 09-30-2011, 07:04 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com Hillsidecycle.com is offline
Sponsor
They are approx 94cc from the Moco.
6cc puts you at your target, and is easily obtainable.
You need to pull those down about .075", before the realeases are in the way, and even then, you can back those off via a crush washer, or copper washer.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
315-495-6650 tel/fax
www.hillsidecycle.com
Palmer's Performance Products
Complete H-D Machine Shop
Case Boring, Cylinder boring
Surface Grinding
Complete Cylinder Head Shop
High-Performance Engine Kits
Super-Flow Flow Bench
Crank Rebuilding
Direct Link Dyno Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
"30 PLUS YEARS OF H-D ENGINE BUILDING."
P
Thread Thread Starter Forum Replies Last Post
Big numbers can come in small packages !!! MCCHP Exhaust System Topics 94 05-31-2014 07:34 AM
Can you bolt the se 110 heads up to a 95 inch motor misfitJason Engine Mechanical Topics 6 03-22-2014 01:41 PM
Acr on side of head in place of manual compression release gpp Touring Models 1 11-04-2012 11:35 PM
Manual Compression releases sticking Rickytic4445 Engine Mechanical Topics 1 08-21-2011 01:05 PM
Compression Release 1977f150 Exhaust System Topics 12 10-21-2009 05:18 PM
Tags
110, 117, cvo, heads, ported, stock, vs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
