how to get compression ratio on 95 build
I have an tc 88. Stock compression,have mackie 510 cams stage1 ac se exhaust. I going to bore to 95 put cast se flat top pistons and street port the heads. I want 9.8.1 compression.Tell me what i have to do to get there please.Such as decking the heads,size of head gasket etc. thanks much.
A couple of points about compression for future reference. There is static compression, corrected or dynamic compression and cranking compression and all should be considered. Corrected and cranking CR will vary depending on the timing of the intake valve closing but static CR will remain the same as it is not affected by valve timing.
There is room for debate about what a reasonable level of corrected and cranking CR for a street build is; some like 9.3 corrected as the limit an some think 9.6 is the limit. When cranking compression approaches 190psi, you are in compression releas territory; maybe not a must but nice to have if/when needed. Compression releases will also extend battery and starter life if used.
A .030" head gasket does drop the static CR by about .25 points less than with the OEM head gasket but the more important reason for the .030" head gasket is to tighten up the squish, also referred to as the quench, area in the combustion chamber for a more complete and efficient burn of the air/fuel charge.
In your application, you will need to deck your heads to reduce chamber volume to about 80cc, with a .030" head gasket to hit 9.8 static CR assuming your deck height is 0.00 which it most likely is not. Typically OEM pistons are down in the hole .003"-.005" which will affect the CR calculation a bit. At 9.8CR, your corrected CR should be about 9.1 and cranking between 185-190psi. Not a bad place for a street build; should be a good runner.
Check out the BigBoyz calculator; it is a handy tool.
Abitrarily doing so will not insure all is right, nor will it take into account variances from one chamber to the other.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
thanks for your info. Iam sending the heads and cylinders in . Just had some questions. Bean will be doing the work i will be installing them.dyno will be done by fuel moto thanks alot
Bean will get it right. You should take the time to learn this stuff anyway but Bean will get it right while you learn.
djl. Thanks for your input and your right I will figure the numbers out. I just keep learning and doing. By the way your numbers you gave me were right on. Thanks jurgie
