Sponsored by: Jekill and Hyde
S&s 570 cams????
Old 12-13-2011, 07:44 PM
dbrown5's Avatar
dbrown5
dbrown5 is offline
Default S&s 570 cams????
i talked to s&s todya and they were telling me that the 570 were close to the same as woods 555.... im planning on getting head work done and putting in s&s 570 cams and needed to know if anyone ran this or had any info good or bad? im looking to go from 0-110 faster than the other guys i ride with
Old 12-13-2011, 07:49 PM
Hakogs's Avatar
Hakogs
Hakogs is offline
I put the woods 777 in a 2011 103 ultra and love it. Power to sell and hells of torque. I chose the 777 over the 555 due to the fact it has just a ltl more lift. You can call Bob woods and talk to him personalty about your build and he will give you a lot of good info.
Old 12-13-2011, 08:38 PM
djl's Avatar
djl
djl is offline
Received 2,030 Likes on 1,498 Posts
The 570 needs more compression to perform up to it's potential; you would need to pull your heads and have them decked for the extra compression.
You will be happier with either the Andrews 26 or 37 or the SE204 for a cam only upgrade.
Old 12-13-2011, 08:47 PM
dbrown5's Avatar
dbrown5
dbrown5 is offline
i should have put this in there i plan on having my heads worked at the same time
Old 12-14-2011, 09:19 AM
djl's Avatar
djl
djl is offline
Good move; 76cc-78cc chambers with a .030" head gasket will get you there.
Old 12-14-2011, 04:55 PM
natural gasser's Avatar
natural gasser
natural gasser is offline
Get the "easy starts". .570 a great cam IMO. 10.0:1 would be a good target.
Old 12-14-2011, 05:00 PM
HDCrossbones09's Avatar
HDCrossbones09
HDCrossbones09 is offline
What kind of numbers should be expected from this set up with a good tuner and a good pipe?
Old 12-14-2011, 05:25 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
If looking for a "cam only" upgrade, then an Andrews 48 is your man, but if you want to be the lead dog, then you may want to consider this;
Bore to 107"
Wood 8 cams
Heads that roll off north of 165 cfm @ 10" @ .600" lift.
Your riding buds could use gps units for Christmas at that point!!
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Old 12-15-2011, 01:34 AM
dcgray2's Avatar
dcgray2
dcgray2 is offline
I also am going with the S&S 570 EZ cams. I am targeting just slightly north of 10:1 static compression which will put me right at 9.3:1 corrected compression.
I also looked seriously at the Woods TW5-6 because of the earlier intake close, however on another forum a member had both on the same build and the dyno charts are not much different.
TW5-6 pulls torque nbrs about 150 RPM sooner and makes slightly less top HP, but they are really close.
Add in the fact that Woods cams are expensive, and the S&S cams include the EZ start so no need for compression releases and I think the S&S 570 is good value for the money.
Old 12-15-2011, 09:28 AM
djl's Avatar
djl
djl is offline
Those cams in a shorter stroke 95" with the early SE Performance heads out of box (76cc chambers), SE flat top pistons and .030" head gasket will hit 100/100 every time.
jack6hd
Engine Mechanical Topics
01-13-2017 12:20 PM
Fxdxt-I
02-05-2013 07:30 AM
RK14SGS
05-30-2012 02:28 PM
CigarDogHD
08-06-2011 09:47 AM
jnickel
10-17-2007 03:11 PM
Quick Reply: S&s 570 cams????
