SE HTCC Intake Manifold Question
About to install 95 BB with head work and modified throttle body. Will SE HTCC intake manifold 9pn29608-02) fit and are there any benefits to be had over stock manifold?
I have 2001 FI Fatboy, se204 cams, se air intake, and V&H 2-1 big radius exhaust. About to install stock cylinders bored to 95, Ross 9.5 CR flat top pistons, heads (1.900 intake valve, 1.610 exhaust valve, 5-angle valve job, D-port exhaust, split port intake, decked .020 to yield CR of 9.8:1 with .040 head gasket), and modified Delphi throttle body bored to 48mm. Heads were setup for these cams to improve low/mid torque. TB also includes epoxy application to increase and smooth airflow to heads, and are setup to match head work.
Here is a pic of the SE manifold and description from seller:
HARLEY-DAVIDSONSCREAMIN’ EAGLE PRO“HTCC” EFI (ELECTRONIC FUEL INJECTION) INTAKE MANIFOLD. HARLEY DAVIDSON PART NUMBER 29608-02. BRAND NEW, STILL IN THE ORIGINAL PACKAGING. THIS EFI MANIFOLD PROVIDES SMOOTH AIR FLOW FROM THE EFI MODULE TO THE VELOCITY “D-SHAPED” PORTS OF THE STANDARD “HTCC” CYLINDER HEAD. THIS COMPLETE KIT INCLUDES THE MANIFOLD, FLANGE SEALS, MOUNTING HARDWARE AND GASKET. FITS: 2002-2005 EFI TOURING MODELS, 2004-2005 EFI DYNAMODELS AND 2001-2005 EFI SOFTAIL MODELS.
