Overheated engine - resulting problems
Please forgo the browbeating as I know I was careless and messed up my Softail. Just looking for answers of what's wrong now.
'03 Heritage, 1450 cc. In an effort to recharge the battery I jump started my bike and let it idle in the garage for about 20 minutes, when I returned to my garage the engine was still running but smoking pretty badly. I shut her down immediately. I also noticed a couple of drops of oil had come down from the air filter area. I let it sit for over an hour to cool and it was still pretty hot after an hour so I checked the spark plugs - they didn't appear to be burnt up or anything, pretty normal looking - and I changed the oil and oil filter - the oil I drained out didn't appear to be burned up either. Both good signs I figured.
After changing the oil and checking her over came the moment of truth, she started up fine and idled normally. So I took it for a quick ride and that's when a problem showed up - as I was obviously nervous right from the start that I had caused irreversible damage to the engine. As I headed down the street I immediately noticed that the throttle had become VERY stiff. Note: At no time did I ever touch the handle bars and throttle during this ordeal. Because the throttle is now very stiff I'm unable to accelerate quickly. I headed home and shut it down. That's the end of my story.
Any thoughts, ideas, suggestions? Any thoughts are much appreciated.
