Sponsored by: Jekill and Hyde
Oil Pump Removal?
Old 04-26-2012, 05:22 PM
NormE's Avatar
NormE
NormE is offline
Stage IV
Default Oil Pump Removal?
Hey guys, do you have to unbolt the oil pump from the cam support plate in order to remove the cam support Plate from the motor?. The Bike is a 03 ultra classic.
Thanks
Norm
Old 04-26-2012, 06:16 PM
remmag's Avatar
remmag
remmag is offline
no you dont, but the pump will come off with the plate
Old 04-26-2012, 08:51 PM
asm481's Avatar
asm481
asm481 is offline
You'll need to have it seperate to reinstall.
Old 04-26-2012, 09:54 PM
NormE's Avatar
NormE
NormE is offline
Stage IV
Thanks for the replies. Why do I need to separate it to reinstall?
Old 04-26-2012, 10:15 PM
harley_jeff's Avatar
harley_jeff
harley_jeff is offline
Because when you reinstall the camchest components, the oil pump assy first goes onto the pinion shaft. When the camplate goes back on, you use two of those tapered bolt thingies to help align the pump housing to the camplate. You have a shop manual, right?
Old 04-27-2012, 12:49 AM
NormE's Avatar
NormE
NormE is offline
Stage IV
I have a manual, But I guess my question is - if I don't remove the oil pump from the cam support plate, shouldn't the oil pump stay aligned?. I have new O-rings for the oil pump scavenge port stub, oil feed hole and blind hole.
Old 04-27-2012, 04:45 AM
RHillbilly's Avatar
RHillbilly
RHillbilly is offline
Mine is a 2011 didnt remove mine to reinstall just put oil on oring and be easy you can feel it go in place
Old 04-27-2012, 03:30 PM
Egldr05's Avatar
Egldr05
Egldr05 is offline
You can do it as long as everything stays lined up in the pump but I would still advise you to loosen it up and realign the pump.
Rick
Old 04-27-2012, 05:25 PM
wheel752's Avatar
wheel752
wheel752 is offline
Use the tapered threads and rotate motor by turning back wheel as you tighten... butt...don't even think about it... without upgrading to new pump and tensioners...
Old 04-28-2012, 09:34 AM
jlb0038's Avatar
jlb0038
jlb0038 is offline
Thanks
Norm
Very interested in this also. In that cam change video from S&S he just leaves it attached to the cam plate. That would make the job alot earsier, IMO. I couldn't post the link, but it you do a search on youtube for Harley Cam Change, its the first one that comes up.
J.B.
Quick Reply: Oil Pump Removal?
