XL1200 First mods
XL1200 First mods
Hey all calling for a head check and if needed a point in the right direction.
I have an XL1200 48. This will be the first messing with her and I am looking at fitting:
Rush full system Shorty Sporty full (Black/ ceramic)
Power commander 5
Kuryakyn Hypercharger / or just go K&N heavy breather
As I would find it hard to fund all this in one go, would it be ok to fit in this order, or do I need the Power commander first?
cheers all
Smudge
Power commander 5
cheers all
Smudge
Hi Smudge, from just down the M6/M1!
You are moving into a grey area, modifying your bike. Changes like that will adversely affect your fuelling, making the bike leaner and possibly run poorly, so you should budget for adding a tuning device of some sort. I suggest that if you are on a modest budget that you buy the parts as you can afford them, but don't fit them until you have the complete set. Then fit and get tuned once, rather than several times!
I strongly recommend you talk to your dealer or a local indy. There are many tuning devices out there, but if you are going to depend on getting local technical support, buy something they recommend and can support. There is no point buying the 'best' tuner, then finding nobody nearby will touch it!
Good advice.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
