Sportster only runs with choke
I have a 1996 Sportster 1200 that I recent acquired that had been sitting for 5 years.
I cleaned the carb and put a battery in it to get it started. It starts right up and runs great with the choke pulled and will die if I push it in after it's warmed up. I've checked for any air leaks and didn't find any. I've took the carb apart 3 times to double and triple check that it's clean. It will run well with the choke half way out.
When I ride it with the choke all the way out or half way out it bogs at lower RPM's.
I could use some help trying to figure this out.
If it's been standing with fuel in it for all that time there are several things worth checking. Consider draining the tank to remove and clean the gas tap and filter, also to remove any unpleasant stuff in the tank.
Your running problem could be as simple as the pilot jet being blocked. It actually affects running over the lower rev range of the bike. Don't spend too much time trying to clean it if it is blocked. They are cheap to replace and it is easy to spoil if you can't clean it by blowing through. Get the same size.
Jets for these carbs are aviailable all over the place. By chance one day I stopped in a Yamaha dealer about 10 miles from home to see if they have the jets I needed because my h/d dealer is about 80 miles away. Turns out, Yamaha snomobiles use a carb that had the same jets. $2.25 a piece and only 10 miles from home. Of course you should try and clean the ones you have, but be careful. Best to have a magnafied glass to get a good look at what you are working with, it helps. As far as clearing obstructions from jets, don't get too agressive. Usually made from brass and are very soft.
Last edited by jcb1975@yahoo.com; 08-07-2012 at 11:57 AM. Reason: Assuming you still have the stock CV carb.
