Little Disappointed in Dyno Run
I have about 1900 miles on the 96"---> 103" conversion, so I thought I would get a Dyno run to see what numbers the new engine is producing. I was a little disappointed as the results were 106 TQ/100 HP. (5th gear pull, SAE correction, SAE/5 smoothing). Any easy ways of getting more power? I was hoping for 110/110. Build is TMAN P&P, 777 cams, .030" head gasket, woods 777, woods lifters, SE pushrods, S&S roller rockers, Wiseco 5 cc pistons (compression calculated at 10.25 uncorrected), SE 50 mm throttle body, Rinehart 2-1 exhaust.
#`s are a little low,did you get a flow chart? not sure of the different degree`s of T MAN porting.we do 4 levels of porting,for example with our street port,those would be OK #`s,for our stage II or III,#`s would not acceptable.i agree with the other post that says the pipes are hurting you too,ide do a super meg
Yo_Boss
Engine Mechanical Topics
39
09-24-2016 05:36 AM
