Re-balancing 106" flywheels ???
Have this flywheel assembly: S&S part #32-2242 - Replacement 8-1/4" flywheel assembly for 106" engines with 4-1/2" stroke in 1999 - ' 02 Harley-Davidson® big twin models. These flywheels come with connecting rods and are assembled and balanced for 92-1210 pistons.
Can these flywheels be re-balanced for a 4.125 bore cylinder kit AND be upgraded with a timken bearing on the sprocket side ??????
S&S reply: "The flywheels can be rebalanced for a 4 1/8" bore piston, however, S&S does not have a piston available in that bore for the 4 1/2" stroke. If you are able to find a suitable piston, as long as the weight of the piston is known, balancing should not be an issue.
If the flywheels are set up for the stock roller bearing, simply heat the bearing race on the shaft and pull it off, then your Timkens can be installed.
Technical Support ............
In a world where 117's and 124's rule the road, not much of an aftermarket venue for the 120" twin cam supporting the 4-1/2" stroker wheels ????
We've built several 120"ers here in the past.
They run up in the high 130's/low 140's on hp, set up correctly.
Axtell has 4 1/8" piston/cylinder kits for that 4 1/2" arm.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
Thanks for posting that Scott. I will look into those cylinders and pistons. I have noticed a lot of these big bore cylinder kits have different heights. I have had a little difficulty in searching out cylinder heights, rod lengths, and piston weights. I am not adverse to turning the base of a cyl to come up with the right deck height, but so much of the info is not available to me yet. Even the piston weights of the S&S 106 pistons are difficult for me to find.
