A decent amount of oil coming from carb
First of all motor is a 1988 evo with s&s super e carb. I have been running this setup for 6 years and now all of a sudden it started puking a little bit of oil from the carb. I thought my base gasket was seeping until I notices the bottom of the air cleaner was soaked. I pulled the air cleaner cover off and found a pool of oil. The air filter element was soaked too. The bike is running awesome and about a month or two ago I put some new baffles in the pipes (also carb jet) and it does cough every now and then. It has never done this. Any suggestions or ideas for the cause? Thanks in advance Jason
Umbrella valves no longer pliable?
Rings toast?
A leakdown test would alert you to rings.
Scott
Rings toast?
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
hcruz
10-05-2007 11:00 PM
