Cruise control for 07 FLHP?
You can try to check part numbers from Ronnie's or whatever that place is called where you can access part numbers online. Beyond that, maybe call a dealer and ask them. All I know to tell you, looks like nobody else knows. Maybe repost, bump to the top after the holiday weekend. You could also ask the same question in the touring section, might get more responses.
08 and up is electronic throttle whereas you have cable operated throttle. HD no longer offers the cruise control module as an accessory for your fitment. You may find a dealer who can run the part # to see if any US HD dealers would happen to still have on hand but I doubt there are any still available. You may also have a dealer check to see if the OEM module from an Ultra would work in your application. There are aftermarket companies offering cruise control kits.
swipter
06-19-2007 10:45 AM
SteelCityScooter
05-24-2007 01:07 AM
