Sponsored by: Jekill and Hyde
cam wear
Old 12-02-2012, 09:54 AM
hogrunner25's Avatar
hogrunner25
hogrunner25 is offline
2nd Gear
Default cam wear
In the process of upgrading TC 88 to SE hydraulic cam chain tensioners and found more wear on stock cams that I anticipated. I have a 01 FLHR with 29,000 miles. Does this amount of wear look normal? It is not rough to the touch, but definitely does not look like new.
Should I replace these cams?
If I upgrade to new cam and lifters, any recommendations for mild upgrade keeping stock pushrods, etc. I have Mikuni 42 and D&D two into one exhaust.
thanks for any help!
Attached Thumbnails cam wear-dscn0052.jpg   cam wear-dscn0053.jpg   cam wear-dscn0054.jpg   cam wear-dscn0057.jpg
Old 12-02-2012, 10:26 AM
djl's Avatar
djl
djl is online now
Received 2,030 Likes on 1,498 Posts
Looks like the cam lobes did not take the case hardening very well. What did the lifter rollers look like? A set of Andrews 21 or 26 cams with new lifters will wake things up.
Old 12-02-2012, 10:36 AM
QC's Avatar
QC
QC is offline
Received 19,786 Likes on 9,863 Posts
Agree with above on both counts.
Old 12-02-2012, 12:54 PM
hogrunner25
2nd Gear
The rollers looked better, although one had a visible line (could not feel ridge) running all the way around the roller.
thanks for the recommendation on the new cams, I'll check out they lifters also.
Old 12-02-2012, 02:14 PM
KumaRide's Avatar
KumaRide
KumaRide is offline
21's with your 2n1 is a nice 88" combo for low to mid tq increase.
Old 12-02-2012, 03:01 PM
Kbore's Avatar
Kbore
Kbore is offline
Even if they look perfect, replace them. That is is you want a huge performance and ridability improvement!!
Old 12-02-2012, 05:00 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
We've seen those on 1 bike of that vintage, (with only 1200 miles) that had grooves cut into the lobes approx .060" deep.
Andrews 26's are a great choice, and you can build from them, later, if so desired.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Old 12-02-2012, 07:09 PM
INDEPENDENT_1's Avatar
INDEPENDENT_1
INDEPENDENT_1 is offline
Agree with djl and Hillside. Andrews 21 or 26, new lifters, new inner cam bearings and a set of adjustable pushrods.
Old 12-02-2012, 08:42 PM
shineola's Avatar
shineola
shineola is offline
Default Cams
Crane 6000-1
Randy L. Beckner
03-30-2019 07:24 PM
kllrvet
Milwaukee Eight (M8)
07-02-2017 07:19 PM
Molarman
12-26-2012 05:32 PM
remmag
02-24-2011 05:58 PM
Timex
04-12-2006 08:16 PM
Quick Reply: cam wear
