Head gasket size. Andrews 57h
12-18-2012, 10:07 PM
I am finishing up my build having added the SE 103 kit and Andrews 57h cams. Should I go with a .030 head gasket or the stock .040?
Thx
12-18-2012, 10:37 PM
the .030 will give you a little more compression
12-19-2012, 03:14 AM
.030 squish is optimal, but you need to check your deck height. You can use a .027 if the piston is down in the hole too far, but you can also cut the bottom of the barrels. It is an extra step but it's the details that make the difference.
Mike07roadking
04-12-2018 01:00 PM
brad75raiders
Engine Mechanical Topics
01-27-2017 11:39 AM
Dyna7
12-29-2013 01:03 PM
troop
02-19-2010 05:23 PM
loc
Exhaust System Topics
03-02-2009 02:47 PM
