Need CAM Recommendation please!
Some info: 02 Softail Deuce 88b with D & M Power Flow Intake and Freedom Performance 2 into 1 exhaust & SE ignition, otherwise its stock. Im right at 20k mileage and along with the 20k service I want to do hydraulic cam chain tensioner upgrade and cams and will send heads off to Big Boyz for street port. I am also going to go with SE Pro Big Bore 44mm CV Carb.I dont plan on 95 upgrade. With this configuration I would like a cam that would put my torque in the 2200-5000 range. I would like some recommendations as to what cams would work best in that range. Thank you all for responses.
Contact your porting service as to their reccomendation.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
+1 on Hillside's comment. I would ask Big Boyz what cam they recommend because it can make a difference depending on exactly what they do to the heads. We do more S&S than anything but we also like Woods Performance and some of HD's higher performance cams for bigger builds.
We surely believe the motto "there is no replacement for displacement". We would suggest upgrading your pistons/cylinders.
Last edited by No Name Motorcycle Shop; 12-21-2012 at 08:35 AM. Reason: adding content
