Cam Upgrade? Andrews, Crane or Cycle Rama?
I have a 2007 Harley Davidson Ultra Classic with the 96 CID six speed transmission (Stage1) and I'm looking to upgrade my torque in the 2000 - 4000 range. There are several different cams I'm looking at to achieve this goal. Has anyone had any experience with any of the following cams?
Crane HTC-300
Cycle Rama 575H
Andrews TW21
Andrews TW26
Not looking to upgrade to the 103 at this time. Just need to know if anyone can point me in the right direction in regard to the above Cams. I'm leaning towards the Cycle Rama 575H but I've also read great reviews on the Andrews and the Crane. . . decisions decisions. . lol Any input would be greatly appreciated!
Crane HTC-300
Cycle Rama 575H
Andrews TW21
Andrews TW26
Andrews 48's.
That cam was specifically designed, to do just what your looking for.
Once tuned they show just about 90 hp and 100 ft/lbs.
Got 'em on the shelf, with all else needed, for an easy install.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
Crane HTC-300
Cycle Rama 575H
Andrews TW21
Andrews TW26
Crane HTC-300
Cycle Rama 575H
Andrews TW21
Andrews TW26
Andews 48 like mentioned, T-man 555 torquester, , S&S 551 (personal favorite) You have the springs for more lift over the 21 or 26 so you might as well take advantage of it.
Don't mess around with the Andrews 21 or 26's in a 96" motor.
Scott's right, the Andrews 48 is a good cam that will come on in the rpm range you're looking for (sooner actually). A lot like a high lift Andrews 21 cam. The Cycle Rama CR575's are also a good cam set up at 9.8:1.
Another you might want to consider is the Woods TW222’s.
Aint that a fact.
Aint that a fact.
BVBOB - What's the difference between the 48's and the S&S 551's you like so much?
Thanks for all your Input Guys. . .Much appreciated!!
The sheet below is from a 551 setup that I first did a baseline on when it was a stage 1 and then with the addition of the cams and tune, I have yet to see one below 100 torque and I now keep them in stock for 96 inch cam only swaps. My best guess would be that the 48 may come on a tad bit later but hold a broader curve.
I'm very interested in the 48's for my 08 Ultra with stage one as well. What am I looking at price wise for the cams, adjustable push rods and full set up?
I don't have a sheet for a bolt in only 48, I do have one from a 107 with some headwork, did very well and has the nastiest idle which I did not expect.
Thanks for all your help BVBOB!
