Andrews 26A Cam Upgrade
Have a couple of questions about doing a cam upgrade.
I have a '06 Road King with the new Cam Plate with hydraulic tensioners already installed. Now I plan on putting Andrews in TW26A cams.
All of my documentation refers to the original plate and tensioners.
Is there any other documentation around that explains the steps (and any special tools) to remove the old cams and put in new cams after the new plate has been installed?
Thanx in Advance.
Thanx in Advance.
Thanx in Advance.
Thanx in Advance.
If running the 26a cams and hydraulic tensioners, you must have installed the SE Hybrid kit?? If that is the case, the service manual will provide all the instruction you need. Upgrade the inner cam bearings to Torrington B-148s while you are in the cam chest. Google/search for the "freezer/oven" method to install outer cam bearings and assembly into the cam plate to avoid special tools to R/R outer bearings and the requirement for a press.
You will need the shim pack for the rear cam sprocket as well.
Hyd tensioners are bolt on, nothing to unload or pre load for removal/installation.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
