Cams
203 comes on earlier and doesn't carry out as far. True duals on a 88"er usually hurt bottom end and, if that is the case for you, it will be more noticeable with the 204s. A 2:1 will usually correct that early torque dip. Both cams need more than stock compression to shine. I have run them both in 95" configuration with worked heads and 9.8 compression and the 204 is a much underrated cam. A set of 204s in a stock 103" motor will surprise you.
As djl has pointed out, the better of the 2, for what you currently have would be the 203's.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
Well, how about because they like the look and the sound? I like the Rinehart TDs on my 107" FLHT; runs strong and sounds good. Not too loud but authoritative when the throttle is applied. TDs are fine on larger displacement motors. JMHO.
I have the full sac cheapy true dual set up with rineharts and certainly noticed no seat of the pants difference, if I lost anything down low I can't feel it so I'm thrilled.The heat reduction on the right thigh is worth the price alone not to mention a proper balanced sound.
