Cam suggestions
Cam suggestions
Any suggestion on what cam to use in a 1999 twin cam?
1999 Electra Glide Classic (EFI)
Screamin eagle air cleaner?
Two up and some solo riding about 50/50.
Riding back country roads and cruising.
Rush True Dual exhuast.
Powercommander III USB
95" 1550 WISECO PISTON BIG BORE KIT 9.1 cr
96" Stock Heads off 2010
What year are your heads? I expect newer then 2006? Are you getting head work for your 96" heads? Let the head porter recommend the cam... They will port the heads with the cams in mind. I have the same bike as you...great ride isnt it!
I have a 1999 Ultra that had a stage 2 from Harley with SE203's, PC2, V&H 2-1 with a SE6-speed an 3.37 gearing. It did ok... I purchased a used set of heads at a swap meet for $100 and sent them to WFO Larry for the stage 2+. They have springs set for .600 lift and believe they are similar to what springs are in a 2006 an up heads. Larry also put in 1.9 intakes and 1.6 exhaust. Before I did this work I converted to an CV44 carb, got tired of adjusting the M&M FI.
The cam I recommend is the Woods 5 or 5-6 if your run out it more then .003. Mine was .004 so I went with the hybrid plate and the 5-6 and the newer style chain tensioners.
Big Blue pulls like a freight train on the run!
96" Heads
96" Heads
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
Did you understand why HD and most performance pipes are connected? I recommend you find that out be fore going true duals I know why but you might not beleive me even thaw I have been ridding and working on Harley s none stop for 42 years.
Have you looked at the S&S 509? No head work and works great with stock compression. If you are looking for a low to mid cam check it out. It is fairly new.
Good luck.
Good luck.
eds06roadglide
02-11-2011 11:36 AM
eds06roadglide
11-14-2010 01:28 AM
eds06roadglide
11-12-2010 11:42 AM
