red hot head pipes 13 heritage
Not normal; sure sounds like a bad tune.
There is dyno tuning and then there is real dyno tuning. Some tuners will load a map, put the bike on the dyno, tweak the map and call that a tune. A proper dyno tune will take several hours and could require 30-40 pulls. A well tuned motor shouldn't show that kind of heat that quick. Heck, a stock motor, even with the lean factory settings shouldn't show that kind of heat that quick. JMHO.
