want to build a 112 cubic inch
I was doing some research tonight about how to get more cubic inches and it arose a big question with me. Why has nobody took a set of stock cylinder, bored them to 3.932 like a 107 build, and use a 4 5/8 crank? If my math is correct this would give you a 112 cubic inch without having to bore the cases. Is this feasible or am I completely out of my mind here?
I would imagine that custom pistons could be ordered,(?) but a 107"er, set up correctly is a very formidable powerplant.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
JMHO but I think you are going the wrong way.
How much torque an engine can make is based on its cubic inches. Torque comes from how much air the engine can ingest every intake stroke. The more the cubic inches, the more air it can take in every stroke.
How much HP an engine can make is based on the total valve area. HP comes from the total air the engine can ingest per unit time, like every second. The intake valve is typically the largest restriction for air flow in an engine. Therefore, an engine with more intake valve area (total valves in the engine x valve area) can ingest more air than one with less valve area. Or, it can rev higher before it runs out of breath. Higher revs mean more HP.
If we look at an oversquare engine, its larger bore allows for larger valves to be used. Therefore it can make more HP than the same cubic inch engine with a smaller bore. That’s it; it’s just that simple. The old axiom that long stroke engines make more torque is related to this. It’s not that they make more torque, its just that they can’t make HP because the valves are just that much smaller to fit inside the smaller bore.
Then you must consider the piston issue. Like Scott pointed out, there is not off the shelf piston for that configuration; you should asking yourself why?? Associated with the piston is the piston speed, sidewall loading, scuffing, heat all the other issues associated with the accelerated piston speed that configuration will generate and you are putting those loads on a cylinder spigot that some think is too thin for shorter strokes.
The lower unit has to come out to replace the crank; you have to do that anyway. Don't reinvent the wheel and **** away a bunch of money to end up with a motor that won't deliver. Stick with tried and true configurations; spend the extra $300 or whatever it costs to have the cases bored for larger cylinder and build a 117" motor; 4.125" bore x 4.375 stroke. Headwork and the right cams and it will deliver neck snapping torque without all the issues that will come with your stroker plan. JMHO.
Those .590's are good, but there are others out there that will offer even more.
As djl has pointed out, a 117" engine can be VERY powerful, but if looking for all the gusto, then a 124".
They carry a 4 5/8" stroke, and combined with headwork, and a cam that compliments your riding wants/needs, you'll not be lacking anywhere.
Scott
Scott
Scott,
How much of a difference would I see between a 117 and a 113? I can get a really good deal on a set of new 4.060 cylinders and pistons to build a 113. I know the 4.060 cylinders do not come perfectly straight so I would get the 0.010 over pistons and have the cylinders honed to the pistons.
Can I get an "Amen"? Set up right, TMan's 590 is a runner.
Not trying to derail the thread but what are we talking about here!!!^^^
