EFI Coversion or 98" cylinders
you already have good parts in the engine.The stock MM EFI Is crap.. Yeah it is cheaper to convert to a carb but A good EFI System is the way to go. I have converted 2 bikes using the complete S&S Single bore EFI conversion kits and the results are night and day. Zippers also makes a complete kit as well. expect to spend about $2000 for the kit plus the labor to install if you do not have the capabilities.Going from 95 to 98 you wont even notice it.
Welcome to HDF from the UK. It is not true that MM is crap, it just isn't as tunable as the later systems. If your bike has been set up well and is running fine at present I doubt if you will gain much changing anything you mention! If you want even more performance I suggest talking to a competent tuning shop and ask their advice on what further changes you can make. Your engine already has a fairly expensive set-up and any worthwhile changes may need you to dig deep!
A good tuner can work with the MM EFI; certainly not the best but I can't see spending $2K to convert to another EFI system. Plenty of MM EFI systems supporting similar builds.
One thing you might consider is taking advantage of the .585" lift the CNC heads offer. A cam change, more compression and perhaps an exhaust upgrade, along with a good tune of course, will wake things up for much less than $2K.
A good tuner can work with that Magnetti-Marrelli system.
Dan Thayer of Thayers Sales & Service, Corfu, N.Y., has tuned our 98"/37 cam/Stage II Head combo's to 108/111, but those were single bore Delphi's.
www.joescyclerepair.com, just north of Albany, N.Y., works with those MM systems quite well.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
Scott
Scott
Thanks for the info. !!!
tata455
18
12-28-2022 12:39 PM
