Sponsored by: Jekill and Hyde
roller rockera, noisey?
Old 12-16-2013, 09:15 PM
senna's Avatar
senna
senna is offline
Default roller rockera, noisey?
I am concidering roller rocker for my 107 build, but keep reading about them being noisey. That does not make sence to me, I would think a quality roller rocker (s&s) would be just as quiet as stock rocker arms.
What is the general concesus on roller rockers?
Old 12-17-2013, 10:39 AM
HD Pilot's Avatar
HD Pilot
HD Pilot is offline
Well I'm not the expert but I think the experts would want to know what lift your cams have before they weigh in. Might throw in info on your headwork if any.
Old 12-17-2013, 10:57 AM
djl's Avatar
djl
djl is offline
Received 2,031 Likes on 1,499 Posts
Some are more quiet than others but all are noisier than stock. I have only run Jim's and SE rollers, same thing; however, I understand that Crane rollers are less noisy but cannot testify to that as I have not run them.
Unless lift is greater than .600", you are wasting money on rollers. Rollers sound like a sewing machine on steroids. I run .600" lift cams in my all bore 107" '02 FLHT with OEM rockers because the Jim's roller rockers I was running made more noise.
Old 12-17-2013, 12:12 PM
senna's Avatar
senna
senna is offline
I am at .575 lift. Coming from an automotive back ground, I want to believe there would be advantages with rollers
Like
Less friction, that's a plus
More accurate valve timing, that would have to be a good thing.
I just don't understand what makes roller rockers noisey?
Old 12-17-2013, 01:17 PM
djl's Avatar
djl
djl is offline
Like
You are over thinking. The motor is a vtwin, air cooled, pushrod, odd firing design that has basically remained the same for 100 years and spends most of it's life operating life between 2500 and 3500 rpms; no comparison to today's automotive engines.
It's your money, buy whatever you want but, as I said previously, you gain nothing in the way of performance that can be measured by investing in roller rockers. However, they will make more noise than the OEM rockers. Why? I can't answer that but having run them in my own bikes and installing them in others, I can tell you that they will make more noise than the OEM rockers. Heck, you might even like the noise for all I know; your ride, you decide. JMHO.
Old 12-17-2013, 06:00 PM
0ldhippie's Avatar
0ldhippie
0ldhippie is offline
I have S&S roller rockers in my '09 (just because I had a set) and yes they make some noise.
dlynch851
EVO
06-09-2016 04:28 PM
ThisIsMe
09-22-2014 10:49 PM
Dun Roamin
Engine Mechanical Topics
18
06-08-2014 08:47 AM
cruzmisl
09-18-2012 11:10 AM
feguy1
08-28-2012 08:52 AM
Quick Reply: roller rockera, noisey?
