How-To Modify Stock Mufflers on a 2014 Iron 883 (Pics & Vids)
I would be willing to bet the farm that if you dyno that muffler mod compared to a set of good slip ons, you'll be amazed at the low end power loss due to just having huge open cans.
Think of it like this, all the muffler makers could make them a lot cheaper if they just ran open cans and put a deflector in them. instead, they spend hours and hours designing and testing baffles that find the best balance between getting the most low end and the best peak hp. That's why many manufacturers will have different baffles depending on the engine size / build.
Years back I did many comparisons of opening the mufflers and dynoing until there was just a head pipe. Low end was terrible with the really open stuff, peak HP was about the same though.
I'll bet they're nice and loud though!
Hi. Sorry if this is in the wrong spot. I'm in the process of putting on a full exhaust system. I went to remove the gaskets, but didn't see any. Then I tried putting in the SE ones and they didn't fit properly without bunching so I left them out. Service dept was closed today. What are your thoughts?
The original gaskets are a cone shape on the side that receives the pipe made of wire mesh with composite material in them that crushes down. Usually you pry them out with a hook or a screwdriver.
Odds are you simply installed the new exhaust onto the old gaskets and it probably won't leak.
johnteller (06-05-2016)
Great thread btw. I love the step by step you posted!! I just bought a 2016 883 a couple of months ago and wanted the pipes to be loud. Just didn't want to spend a lot of money right now on pipes. My question is would you need to get a tuner after you modify the stock pipes? N second I was just thinking about taking the muffler part off where the baffles are? Didn't know if it would damage the Engine?
