Barn-Fresh WL
Old 04-29-2012, 05:03 PM
WLratbike's Avatar
WLratbike
WLratbike is offline
3rd Gear
Default Barn-Fresh WL
Two years ago:
Mostly complete, unsure of why it was partially disassembled, but its relatively rust-free and came with a restoration manual.
The bike belonged to my wife's grandfather and I decided to keep all of the 'character' intact.
Old 04-29-2012, 05:17 PM
WLratbike's Avatar
WLratbike
3rd Gear
The bike has been off the road since the 70s, so needless to say: the tires and tubes got replaced due to dry-rot. A new coil, wires, and spark plug were installed as well as a front intake cam. The rear headgasket was blown (common problem on these engines) so it got replaced with a new copper gasket. The rear needed new brake shoes and while I was replacing them, I noticed the backing plate was cracking where the pivot bolt went through. I deemed it fit to weld it into one solid unit as a fix.
Attached Thumbnails Barn-Fresh WL-head-gasket.jpg   Barn-Fresh WL-front-intake-cam.jpg   Barn-Fresh WL-rear-brake-bracket.jpg
Old 04-29-2012, 07:58 PM
Captain Itch's Avatar
Captain Itch
Captain Itch is online now
Sponsor
Looks like a nice project..I f you run in to some major stumbles let me know.Myself and a couple of buds can find a lot of things still for the 45s.I had to pull my generator today for a little TLC..JUST TAKE YOUR TIME THESE OLD BIKES WILL TEACH YOU PATIENCE.. Here is my 49..Good Luck.
__________________
www.Captain-Itch.com
Old 04-30-2012, 08:10 PM
WLratbike's Avatar
WLratbike
3rd Gear
Nice bike there Captain!
Old 04-30-2012, 08:14 PM
WLratbike's Avatar
WLratbike
3rd Gear
Fixed a couple leaks in the gas tank and rebuilt the carb and got it running. I built a seat bar from scratch to mount the repop buddy seat (ill see if I have a photo). The speedo drive gear and speedo cable were missing, so I got some new ones too.
Old 05-01-2012, 09:05 PM
WLratbike's Avatar
WLratbike
3rd Gear
I encountered my first major setback after a couple of test rides. I noticed the rear drum/sprocket assembly was loose where it attached to the wheel hub. I went to torque it down only to find that one of the bolt holes was stripped out. I pulled the drum assembly from the wheel only to find that not only were the alignment pin holes all 'egged out' the pins themselves were missing.
Old 05-01-2012, 09:12 PM
WLratbike's Avatar
WLratbike
3rd Gear
To avoid buying a new drum assembly and hub assembly (and having the wheel laced) I have come up with a solution that I hope works. The first step involves drilling out the 5 original bolt holes and tapping them 7/16-20 and using oversize bolts. The next step is to drill out the alignment pin holes and tap them 7/16"-20 as well for socket head cap screws. The new '10-bolt' setup will give me over twice as much clamping power than the original '5-bolt' setup, hopefully remedying the problem.
The alignment pins working loose damaged the mating surface on the drum, so I chucked it up in my lathe and resurfaced it.
The drum coming loose chewed up my speedo drive gear pretty badly, so I'll probably need a new one of those...again
Old 05-01-2012, 09:18 PM
1CdnHD's Avatar
1CdnHD
1CdnHD is offline
I'm diggin it... nice work.
Old 05-04-2012, 06:42 PM
WLratbike's Avatar
WLratbike
3rd Gear
The oversize bolts came in today, so I reassembled the drum to the hub with some red thread locker and hit the conical bolts with a torque wrench and torqued the new bolts as tight as I could with my hex key cut to fit in between the hubs. I'll give it 24 hours to fully cure (hoping for the best odds of success here) and take it for a test ride tomorrow.
On another note: will I burn out any electronics or do any damage if I run the headlight constantly?
Old 05-04-2012, 07:30 PM
panz4ever's Avatar
panz4ever
panz4ever is offline
Received 3,222 Likes on 1,483 Posts
If you have the 3 brush 6 volt you will need to adjust the 3rd brush to accommodate this
Quick Reply: Barn-Fresh WL
