Model WL Tranny Sprocket Leak
I have replaced the seal behind the sprocket that drives the chain to the back wheel and the tranny oil still leaks out on the exaust. This seems like a weird system that the seal presses into the spinning sprocket and is supposed to seal against the outside of the case while it is spinning! Does anyone have a clue how to stop the leak?
I don't have a manual in front of me right now, but my manual (the military manual for WLA's) gives a specific number of ounces. I know the fluid level in the case has to be below the bottom of the bearings on the sprocket side. If I get a chance, I will find my manual and repost finding.
I have a WLA that i have converted to foot shift, Hyd clutch , belt drive (primary and drive), Kubota alternator, Hyd brakes, mag ignition, - my trans still leaks badly ( especally since I don't need it on my belt) but I will have it apart HOPEFULLY by weeks end and do some sort of seal mod to solve the problem - seems to be from the kick shaft and the sproket output shaft - have any of you guys found a way to seal these two shafts so you get NO LEAKS ? It's not over full ! been considering STP in the trans after I fix the leak . Any suggestions on special seals etc would be welcomed .
Rusty bike
Rusty bike
Take your new seal, install& soak overnight in diesel. Then install , of your leaking & you have the proper amount of oil, you need a total overhaul, new bushings etc. & I have never seen a 3 speed with a hyd clutch, & have been building 45s for years, id be interested to see that. If you are running a stock 3speed,it's going to leak, if you stop it from leaking, it's because your out of oil.
Soaking the seal in diesel will make it swell a little but the real fix is to...
Dissemble tranny again...
Find a Standard Size Viton O-Ring that a groove can be machined for it to ride in; need to get a competent machinist with a lathe/mill to cut the o-ring groove...
That's pretty much the fix for any leaking Pre-Evo H-D Tranny...
Motor Co., Design flaw...
One source of many for Viton O-Rings...
http://www.marcorubber.com/viton.htm
