Help! Metal valve stems & tpms caps
Two Questions:
1) Did you take off your rubber stock valve stems and put on the METAL ones? If so do BOTH valve stems stick out the same amount? Or is the METAL valve stem longer or shorter?
2) If you did the above, take off the stock rubber valve stems and replace them with the METAL ones, did you also put on the TPMS valve stem caps on the new metal valve stems??? IF so, did u do that to a touring bike?
Thank you,
BuzzCap7
Thank you,
BuzzCap7
I was told the metal valve stems will not work since they are too long. When you try to put the caps on top, they will not fit. There isn't enough room.
I am very glad to hear you say that. So u did not have to get special metal valve stems, u used the regular ones HD has to offer eh?
BuzzCap7
The indy, where I bought and had the tires mounted, knew what size to use. They were the same length as the stock stems.
I told him, when I had new tires put on, to use metal valve stems.
Wasn't a problem for him at all.
The instructions that were in the box, recommend metal stems.
BuzzCap7
Again, thanks for the idea, GOOD thinking!!!!
Getting this project settled in my mind is VERY helpful.
BuzzCap7
BuzzCap7
