Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Front suspension leak
Old 04-26-2015, 10:28 AM
Grog's Avatar
Grog
Grog is offline
Default Front suspension leak
My '88 EGC has had a slow leak from one of the front forks. Originally I thought it was the brake caliper but I have had the bike on a lift for the past couple weeks while I work on the wheels. Since the calipers have been hanging loose I can see that the leak is from the fork from where the oil drip is landing. I wiped the slider clean and a day later I can see a drip forming above the drain port.
My question is do I have an issue with only the upper seal of the fork, or is there also an issue with the internal valve? I am wondering this only because the suspension has been hanging for so long the I would think all the oil would have dropped to the bottom of the fork by now and not be coming out of the upper seal, or did the previous owner just over fill the fork?
Has anyone seen this before?
Hunter bee
09-22-2017 02:35 PM
FL-kruzen
11-23-2012 07:38 AM
HDAce
VRSC Models
03-15-2011 06:21 PM
DWhite
04-22-2008 03:52 PM
billnourse
10-09-2005 12:50 PM
Quick Reply: Front suspension leak
