21' front wheel conversion?
i am converting to a renegade 21' front wheel on my 07 streetglide,my question is..what should i use as far as lock tite for the rotor bolts and axle bolt? and what are the torque readings for both,any help would be extremely helpful...since how the harley dealership will not give out torque specs cause they don't want to become liable.thanks Zach
RE: 21' front wheel conversion?
First thing the best money you can spend is to buy the HD service manual.
brake disk "rotor" front 16-24 ft. lbs" new bolts from dealer" blue locktite
rear 30-45 ft. lbs
axel clamp pinch nuts 132-180 in. lbs "right fork leg" 132 in. lbs ÷ 12 = 11 ft. lbs
front axel 50-55 ft. lbs
rear axel 95-105 ft. lbs
brake caliper front28-38 ft. lbs
I just put their wheels on my Street Glide
Mike
rear 30-45 ft. lbs
Mike
ORIGINAL: 07bagger
so it wont clear without moving fender up? they said direct bolt-on no mods needed.
LED tailight
smoked turn signals
custom airbrushed derby and horn cover
lowered 2-1/4'
extended headlight ring
kuryakin highway pegs
chrome switch housings
quick detach sissy-bar
RENEGADE 'NIGHTMARE' wheel coming soon.
You didn't get the rear.
yes thank you for torque specs. i just called renegade and PM and they said that with a metzler tire there is no mods needed for the fender,it's the avon tire that will grow as the speed increases but the metzler only grows like a max of 1mm at almost 130mph. also i didn't order a rear wheel cause it's alot of money for something that you can't see. Zach
From what I see now, the new wheel and tire will be 2.5 inches taller than stock.
diameter of first wheel
16
inches
width of first tire
130
mm
aspect ration of first tire
0.9
percent
half height of first tire-mm
117
mm
total height of first tire-inch
9.2
inches
total height wheel/tire
25.2
inches
diameter of second wheel
50[/size][/font]51
inches
width of second tire
120
mm
aspect ration of second tire
0.7
percent
half height of second tire-mm
84
mm
total height of second tire-inch
6.6
inches
27.6
inches
16
inches
width of first tire
130
mm
0.9
percent
117
mm
9.2
inches
25.2
inches
50[/size][/font]51
inches
120
mm
0.7
percent
84
mm
6.6
inches
27.6
inches
