FLHTC Rear Wheel
RE: FLHTC Rear Wheel
There is no bearing differance between these years. 99 and older run the tapered bearing where 2000 and up run a sealed bearing. Now there might be a differance in axles. As some post 2000 models still used the 3/4 inch axle and others changed to a 1 inch axle. This is somthing you might want to check into by the models you are changing around to make sure you have proper fitment.
