head steering bearing
I have not PACKED my 09 FLHR YET with grease.. I understand that it takes upwards of 88 pumps from a hand gun...
I plan to do this BUT just wondered what type of grease DOES HD use.?. If I don't get an answer here I would ask at the dealer when there....
I know that the best thing to do when apart is to Clean out all the lube/grease that is in there.
I would IF APART to install NEW Bearings and races, I would go with packing them with a Good Quality Blue trailer wheel bearing BLUE/GREEN Grease.
That grease Doesn't MIX with the normal molly grease BUT when cleaned out and fresh bearings/races, it does a better job and Last a long time. Keeps the water elements out better. (.)
Suggestion told me.
If you wrap a shoelace around the bottom of the Head Tube when Pumping in the grease, that will help grease TO come out the top of bearing area so it is NOW full.
signed....REDHEAD
Suggestion told me.
signed....REDHEAD
General Hangover
06-29-2019 10:40 PM
