Sportster solid rear wheel
Hi all, new to this forum....
I have a 2008 883 Sportser and I'd like to fit a solid rear wheel.
Do I need a Sportster wheel or will a Fatboy/Softail/Dyna wheel fit?
Also if the wheel is the right size (16x3) can I just swap out the bearings from a different model or is there other specifics I need to think about?
Thanks for any info!
First off - welcome to the forum.
This post is located in an area that doesn't get a lot of traffic - but you don't need a lot of traffic, just an answer...
If you want a solid wheel, you won't find one off a Dyna. But... A 2000 - 2006 Fatboy rear will fit.
I bought one off Craigslist and it was a direct bolt on (using my stock spacers) for my 05' WG.
From the HD website on the FatBoy rear wheel -
16" Rear Fits '00-later XL (except '11 XL883L), 00-'05 DynaŽ, '00-'02 SoftailŽ (except FXSTD), and '00-'08 Touring models
Thanks heaps for the reply... I hope you may know, I have found this wheel on ebay http://cgi.ebay.com.au/ws/eBayISAPI....=STRK:MEWAX:IT would you know if it fits by just swapping bearings??? Appreciate your help!
No bearing swap necessary... (as long as the existing bearings are in good shape)
Just bolt on your pully & rotor (using new bolts!) and reinstall to your bike using your stock 3/4" axle & spacers.
Literally, that's all I did for mine.
