Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Adjusting Drive Belts On Baggers (PICS)
Old 08-07-2005, 04:25 PM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
Default Adjusting Drive Belts On Baggers (PICS)
Rear Belt Drive Adjustment
Performance and Technical information on the rear belt drive for Harley-Davidson motorcycles.
Belt Drive Adjustment for Big Twins
Set belt tension a the tightest rotational point on the sprockets.
The adjustments should be done when the bike is cold.
The adjustments should be made with the weight of a rider on the bike.
1. At the lower strand, position "A", mid-way between transmission sprocket and rear wheel sprocket, apply 10 Ibs. of upward force on lower span of rear belt. Harley-Davidson has a BELT TENSION GAUGE (Part No. HD-35381) to help.
2. Measure belt deflection "B" several times, each time with belt moved (by rotating rear wheel) to a different position on sprockets. With sprockets rotated to tightest belt posi-tion, belt deflection "B" (measured at position "A") should be 5/16-3/8 in.
ADJUSTMENT
1. Loosen rear axle nuts.
2. Measure each side from the flat to the end of the swingarm, to be sure rear axle is correctly located.
3. Turn axle adjuster nuts (metric) on each side of swing-arm to adjust belt deflection.
a. Turn clockwise to decrease deflection (increase tension).
b. Turn counterclockwise to increase belt deflection (decrease tension).
Turn each adjuster nut exactly the same number of turns to maintain rear wheel alignment.
5. Tighten axle nut to 60-65 ft-lbs.
CAUTION
Keep dirt, grease, oil, and debris off the belt and sprockets. Clean the belt with a rag which is slightly damp with light cleaning agent.
All belts must be handled carefully to prevent bending stress. The belt must never be formed into a loop smaller than 5 inches in diameter and never be bent backwards. Sharp bending can weaken the belt and lead to premature failure. Old belts that are taken off a bike during repairs must be reinstalled so they rotate the same direction.
Tricks of the trade
With a high horsepower engine, it is better to have the belt a little tight rather than loose. A loose belt will break much more readily than a tight one. Most people do not tighten the belt to its proper tension. If you plan on "racing" or hot rodding your bike, invest in a Harley-Davidson BELT TENSION GAUGE (Part No. HD-35381).
[IMG]local://upfiles/2318/C9082F39F5114623BD3EC2423E5B0722.jpg[/IMG]
Pictures submitted by: Billnourse
Here are the pictures of the belt, deflector, window, and deflection gauge.
Gauge: the bottom pushes into the top up to the black O-ring. that is 10 Lbs.
Gauge on belt before compression of gauge. You can see the lip of the gauge in the window on the belt guard, and the marks on the belt guard.
Gauge compressed to the O ring to get 10 lbs. Note that the lip inside the window went up about 3 marks on the belt guard.
Text Reference: http://www.nightrider.com/biketech/hdbeltdrive.htm
clap
08-06-2014 12:19 PM
RockDog
06-06-2010 01:49 PM
big_e78
03-10-2010 09:33 PM
Yachtman
04-13-2009 09:02 PM
kjkustoms
12-06-2008 07:26 PM
Quick Reply: Adjusting Drive Belts On Baggers (PICS)
