49mm Fork oil issue
49mm Fork oil issue
I have just replaced the standard fork springs on my 2007 Dyna with progressive suspension springs. I decided to change the fork oil at the same time and discovered that the oil in the right hand fork was light brown in colour and slightly dirty looking. The oil in the other fork was bright red and clear. The bike has done 8000 miles. Any clues to what may have caused this ?
The harley fork oil is crap. I've no changed it out of 2 harleys that had original fork oil in it and it was plain nasty and stinky.
Watch the seals on the newer dyna's. I had mine replaced under warranty at 3k miles. They also found one of the fork tubes had a slight tweek to it and would have caused 1 of the seals to wear out quick
Best of luck sorting your forks!
