Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Rake and trail
Old 08-23-2013, 04:53 PM
ECC's Avatar
ECC
ECC is offline
Default Rake and trail
Your front suspension geometry is defined by the following six variables which are:
OFFSET: Centerline of the top steering neck to the centerline of the top of the fork tubes.
RAKE: The angle in degrees of the steering neck from vertical.
FORK LENGTH: The distance between the top of the fork tubes to the centerline of the axle.
DIAMETER: The diameter of the front tire.
TRAIL: The distance defined by the vertical line from axle to ground and the intersection of centerline of the steering neck and ground.
RAKED TRIPLE TREES: In order to bring trail figures back into line, triple trees with raked steering stems can be used. Usually adjustable in 3, 5, 7 degrees of rake.
HOW TO MEASURE CORRECT TRAIL
Raise the bike to an upright position, using a tape measure, hold the tape straight down from the front axle to the floor. Put a mark on the floor at that point. Then place the tape parallel to the steering neck, following the angle of the steering neck all the way up to the floor. Put a mark here also. Now measure the distance between the two marks and you have your trail measurement. It should read between 2 and 4 inches. Note: If your bike is equipped with a rear suspension, have someone sit on the seat when you make the measurements to simulate your actual riding condition.
TOO LITTLE OR NEGATIVE TRAIL
With too little or negative trail (steering axle mark behind the front axle mark), the bike will handle with unbelievable ease at low speeds, but will be completely out of balance at high speed. It will easily develop a fatal high-speed wobble. EXTREMELY DANGEROUS!
NORMAL TRAIL
Normal trail is somewhere between 3 and 6 inches. The bike will handle easily at both high and low speeds. Flowing smoothly through curves without swaying or wobbling. If you use a very fat rear tire, you should keep the trail as close to 4 inches as possible.
TOO MUCH TRAIL
If the trail is more than 6 inches the bike will handle sluggishly at high speeds. It will seem almost too steady. You will have trouble balancing the bike at lower speeds or on winding roads. It will feel generally sluggish and clumsy.
brettnbama
04-11-2013 09:07 PM
vindyl
01-23-2011 07:30 AM
JayTee
11-06-2010 11:49 AM
BgEarl
01-20-2010 07:17 PM
traveler
02-05-2008 11:04 PM
Quick Reply: Rake and trail
