Softail Air suspension
I m just about to received my 07 Night Train and i the only thing i havent change on it at the dealer is the suspension , because i want a ajustable air suspension on it !
I have to order it next week so i have to make a choice
Wich system you used on your bike ?
There s option
AIRFX
Progressive AIRTAIL
LEGEND
My choice is going over the AIRTAIL but i have read bad thing about that setup ... I have talk with local shop and the mechanics said that the problem with that system is you have to be very carefull in installing plastic line , so they have not any resistance on it , if not , they will probably leek on the shock fitting ...
Thanks for the help !
Yanick
There s option
AIRFX
Progressive AIRTAIL
LEGEND
Yanick
RE: Softail Air suspension
ORIGINAL: ICEMANNN
There s option
AIRFX
Progressive AIRTAIL
LEGEND
Thanks
I've got the Progresssive Airtail set up on my Fatboy.Put it in over 3 years ago and have had zero issues with leaks.I'm not sure ,but I believe the Airtail and the Platinum work on the same principle.Two airbags that work independent of each other to control the height and the ride quality.I think Progressive originated the idea,but I'm not sure.I do know know that they have a good rep for make world class shocks for all kinds of applications.If your local shop thinks there's an issue with leaks maybe there's an issue with their ability to install things properly.
There s option
AIRFX
Progressive AIRTAIL
LEGEND
Thanks
ORIGINAL: ICEMANNN
How many inches you can lower the bike with the Platinum Air suspension ???
There web site is horrible , no info at all
ORIGINAL: Tx_Outlaw
Check out the Platinum Air system before you buy. I'm running the bleed and feed kit and absolutely love it.
dubless
15
03-25-2008 09:40 PM
