Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
99 Fatboy fork oil change
Old 04-16-2014, 09:38 PM
jvrealpro's Avatar
jvrealpro
jvrealpro is offline
Stage III
Default 99 Fatboy fork oil change
Got this nice 99 Fatboy last fall...been redoing things little by little. Has 50 k miles on it. Now time to replace / verify fork oil...fact is I hear a spring moving around in there a bit when I bounce bike up and down so I have a feeling on or both forks have little or no oil! Rides fine though so not sure.
Is it as simple as jacking bike up and dropping oil out the bottom and removing caps and putting in new oil? Or are there other pitfalls .
Do I need to buy some seals etc first? Hope I don't find rusted springs....
Old 04-17-2014, 04:55 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,499 Likes on 4,612 Posts
Simple process as you described, not sure if the springs are held down by the caps on your forks, so be careful when removing them (follow the service manual). Consider a set of new springs, the ones in the bike have been holding the front of the bike up for 15 years...
I have been happy with Progressive springs, they were less than 100 bucks I think...
If you don`t have oil leaking out, your seals are fine.
Jeff Fish
01-02-2018 05:51 PM
VtwinManiac
05-05-2017 11:54 AM
Golfgurl
02-01-2012 02:26 PM
Nightster_Reaper
02-23-2009 02:30 AM
Paulie420
01-05-2006 06:53 AM
Quick Reply: 99 Fatboy fork oil change
