Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
steering damper for 2005 flhtc
Old 06-10-2014, 06:44 AM
2dreamers's Avatar
2dreamers
2dreamers is offline
Default steering damper for 2005 flhtc
Thinking about installing a steering damper to smooth side load wobble in cornering. I've changed the front suspension with Race Tech with emulators, put Street Works coil shocks on the rear. Tried Bagger Brace with not much improvement. Took off the Bagger Brace and replaced swing arm bushings with Sta Bo's. That helped some. Tires are new, neck bearings tightened and alignment done.
Still have side load wobble over 65 -75mph in corners depending on road surface. Now I'm considering a steering damper before I get rid of the bike. Just tired of getting bounced around in the corners. Any experience with these dampers?
sel53
12-08-2020 07:57 PM
ShockwaveTXB
03-28-2014 03:33 PM
LWright86
02-22-2013 06:11 PM
jmltinc
04-16-2011 04:46 PM
woodeyewetzel
05-20-2007 12:52 PM
Quick Reply: steering damper for 2005 flhtc
