Is Anti-Knock Feature Disabled w/ Aftermarket Spark Plugs?
I was really interested in these plugs, till I did some internet research and found this:
Little known fact:
2005 and later Harley-Davidson EFI systems incorporate an "Anti-knock" feature that operates by reading the current resistance through the spark plugs.
The use of any other spark plug other than 'Stock' (6R12) disables the anti-knock feature.
(Yes, that means the Gold, Platinum and SE plugs will also disable this function)
Here is the website I got that info from:
Here is the Thread that was started on it:
https://www.hdforums.com/forum/softa...ark-plugs.html
Is this true?
That any spark plug that is not stock (6R12) has a different resistance and will disable or give false readings to the anti-knock feature?
I figured you guys would definitely know the answer to this question since you are experts in this area.
We recommend using the stock plugs for best results and to ensure the ion knock retard works properly
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
