How narrow of belt needed to run a 200 tire on a "Wide" Paughco swingarm?
Just ordered a Paughco Softail frame with a 180/200 swing arm. They said that if you run a belt, 180 is as wide as you can go, but that's a 1 1/2 inch belt.. I'm wondering if I could put a 200 mm on with a narrower belt,, if so how narrow would the belt have to be?
Thanks,
Nate
Thanks,
Nate
Thanks,
Nate
Thanks,
Nate
If the frame is wide enough to run a 180 with a 1 1/2" belt you should be able to get a 200 in there with an 1 1/8" belt...but I would mock it up before I bought a lot of parts.
