Hitting the Gas with No GO in 5th and 6th
Old 10-29-2014, 07:47 AM
Ghost_Vengeance's Avatar
Ghost_Vengeance
Ghost_Vengeance is offline
Post Hitting the Gas with No GO in 5th and 6th
Hi Guys!
My first technical question to be asked and hope you guys can help.
What's happening is that if I pull the throttle slowly, power is given to the wheel. When I open it up, the engine goes but its as if its in neutral!
Thanks for any help you can give me.
Old 10-29-2014, 08:24 AM
harleycharlie1992's Avatar
harleycharlie1992
harleycharlie1992 is offline
Unofficial HDF Chaplain
Received 14,552 Likes on 4,606 Posts
clutch slipping for whatever reason, misadjusted, failed, ect. you will need to open it up
Old 10-29-2014, 08:44 AM
harleydodge's Avatar
harleydodge
harleydodge is offline
Agreed. Clutch.
Don't ride it till you look at it or have it looked at.
"limping it" to a dealer or other tech would be O.K.
Old 10-29-2014, 09:44 AM
Ghost_Vengeance
Thank you both for the swift feedback! Much Appreciated!
Old 10-29-2014, 09:50 AM
swordy's Avatar
swordy
swordy is offline
Big Kahuna HDF Member
+3 on clutch
Old 10-29-2014, 11:03 AM
Def Mute's Avatar
Def Mute
Def Mute is offline
Get the service manual...
read up on how to PROPERLY adjust the clutch and/or cable. Your cable could have stretched, or any number of possibilities. Doesn't necessarily mean the clutch itself has taken a dump, but then again, it could have.
No matter 'how you slice it', full inspection of the cable and then adjusting the clutch and clutch cable should be done first before opening the primary to inspect the clutch.
Old 10-29-2014, 11:56 AM
albertasaurus's Avatar
albertasaurus
albertasaurus is offline
Do you hear squealing, and notice a bunch of white smoke coming from the rear tire when you crank it hard?
Old 10-29-2014, 12:06 PM
wwiiavfan's Avatar
wwiiavfan
wwiiavfan is offline
Received 1,070 Likes on 485 Posts
Don't forget you'll want to have a replacement gasket handy if you take off the clutch inspection cover.
Old 10-29-2014, 01:06 PM
oct1949's Avatar
oct1949
oct1949 is offline
Its a good idea to have a new on hand, I used to put a new one on every time I changed the Pri oil, but I realized you can re-use that gasket several times if its not been pinched or flattened out.. I've reused mine for 3 yrs now and never had a leak.
Old 10-29-2014, 05:10 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
If you have a new one on hand chances are you'll never need it, don't have a new gasket on hand you will tear the old one when removing the primary cover. Clutch inspection cover gasket? I don't know , I have never needed a new one, ever!!!!!
Quick Reply: Hitting the Gas with No GO in 5th and 6th
