2002 Road King Swing Arm Pivot shaft replacement
Old 10-30-2014, 08:24 PM
Rustyg500's Avatar
Rustyg500
Rustyg500 is offline
Default 2002 Road King Swing Arm Pivot shaft replacement
I am about to embark on replacing the Swing Arm pivot shaft etal. Have purchased a kit from J&P Cycles which includes pivot shaft, bearings, spacers, motor mounts etc.
The bike has 200,000 miles on it and a couple of years ago I had the pivot shaft off the bike and found the left nut and a spacer to be rusted to the shaft. I got the spacer loose but the nut to this day is welded to the shaft so I figured it is about time to renew things.
Do you all have any words of wisdom as to how to replace bearings etc and what to avoid making this a enjoyable project instead of a nightmare?
PS: I am also trying to up my post count so I can view pictures etc.
Old 10-30-2014, 08:54 PM
MOSTWANTED's Avatar
MOSTWANTED
MOSTWANTED is offline
Subscribed. If nothing else, let us know how it turned out. I might look into doing this some day.
Old 10-30-2014, 09:01 PM
1plumr1's Avatar
1plumr1
1plumr1 is offline
It's a very simple swap. Follow the instructions that came with the kit. I got my kit from Drag Specialties, can't imagine there is much difference. A lift table is a big help.
Old 10-31-2014, 07:05 AM
Def Mute's Avatar
Def Mute
Def Mute is offline
Without the 'nightmares' you will have nothing interesting to talk about...
Good luck with it. I'm interested also, since I've been trying to talk myself into doing that on my '99 RK for the last two years.
Weebles wobble,
hoping we don't all
fall down!.
Old 10-31-2014, 09:06 AM
GoofySB's Avatar
GoofySB
GoofySB is online now
When I did mine, we used a hydraulic press and an arbor press at a friend's place. Worked great for changing the bearings.
Old 10-31-2014, 03:41 PM
Rustyg500's Avatar
Rustyg500
Wish I had that capabilities. Will try with BFH and sockets etc.. Baring success I have an INDY close by that will do the work for me.
Old 10-31-2014, 03:42 PM
Rustyg500's Avatar
Rustyg500
Weebles wobble,
hoping we don't all
fall down!.
I got the feeling the "Nightmares" are going to be replacing the bearings since they are pressed in and I do not have the proper tools. Possibly Autozone loaner program will help here.
Old 10-31-2014, 03:43 PM
Rustyg500's Avatar
Rustyg500
Hooray I got my 5 posts. Now I can see pictures.
Larry Baucum
03-14-2019 08:51 AM
jmn1960
08-08-2015 05:14 AM
sgt. slaughter
12-27-2012 09:16 PM
slyder
11-29-2010 10:00 PM
true-track
01-18-2010 08:06 AM
Quick Reply: 2002 Road King Swing Arm Pivot shaft replacement
