hard starting
hard starting
my 2010 road king classic is hard to start at times. kicks back like its out of time. third try it will start normal or could this be a weak battery? voltage test shows 12.79 battery all most 5 years old.
A static test might show 12 volts, but it's cranking power that really matters. Take the battery to an auto parts store and get it load tested. At 5 years old you're probably ready for a new one but before you do anything else get it tested properly.
Kick back could be caused my compensator. I had similar starting problem, tried new battery and stronger starter no luck. Recently installed a SE comp problem fixed.
https://www.hdforums.com/forum/dyna-...mendation.html
Mine was doing the same thing about a month ago and it tested fine when I rode it to the shop. But cold starting it, it'd drag and act like the battery barely had enough juice to crank it. I finally replaced the 22 month old battery snd it's been like new since.
