Freewheeler rear brake anomaly
On my new Freewheeler (vivid black) when applying the rear brakes I get the "ol bobben for apples" syndrome. It acted ( and felt) like I had a warped rotor. So, back to the dealer. They removed the rear wheels, and said they sandblasted the rotors and brake pads (and said "no warped rotor"). It seemed like it helped for a short ride up the river road ... after that ... right back to the bobben for apples stuff.
It doesn't happen if I use just the front brake. Is it possibly related to the proportioning vale for the new integrated braking system?
Any ideas whould be appreciated. Not only is it embarrassing ... it feels unsafe.
Thanks in advance.
DUH (aka .. EDNHDF150)
"The baits not the trap" .. ride safe .. be safe
Thanks in advance.
Thanks in advance.
Thanks in advance.
i would lift it up and put a dial indicator on it and check all three rotors for runout, and then take it back to the dealer for warranty.
good luck
When I got my 2011 Road King, I would sometimes get a rough vibration when two up and using just the rear brake (which I sometimes did until the wife got used to sitting still while I was trying to stop). I wonder, with all the weight on the rear end of the Freewheeler, if that is what you're experiencing also?
I think that's the way it was happening, it's been a couple of years now since experiencing that. And, I never bothered to have it looked at as it didn't do it when riding solo or when using mostly front brake to slow down to a stop.
Purchased my 2015 FW in Feb have same issue. Dealer looked at rear brakes and said they were within specs. But your comment about a proportioning valve makes sense. Thought the prob could be air in brake lines. Comments? Post results pls.
Note added: The "ol bobben for apples" syndrome posted by EDNHDF150 appears primarily when I only use the rear brake when slowing down from 10-30 mph to a dead stop. Does not happen when front brake is applied at those speeds.
Last edited by jcmana52; 07-23-2015 at 07:42 AM. Reason: adding addl info on braking issue
Thanks in advance.
Thanks in advance.
Yea it's even happening on my 2016 FLRTSE2. So when you find a resolution I would like to have my dealer here try it as well. My girlfriend is getting tired of her neck hurting after all our rides. She said if I didn't get it fixed she wasn't riding anymore.
TRI GLIDER
21
07-24-2009 01:51 PM
