Battery Tender Question
So its that time of year and I put the bike on the tender today after winterizing it. When I plugged in the tender it went green for a couple of seconds then to flashing yellow and it stayed there. Flashing yellow means that the tender is not charging the battery. I took the tender and attached it to other batteries to see if the problem is with the pigtail connector to my bike or if the problem is with the tender.
The tender flashed yellow for all the batteries that I tried it on. So my best guess is that the tender is not functioning. Whats the concensus from people out there, am I right?
Battery Tender troubleshooting does not show a yellow flashing light.
https://www.batterystuff.com/files/t...ng_bt_plus.pdf
What brand of charger do you have? I have two of the Deltran Battery Tender Juniors and both have red and green lights. No yellow. Flashing red indicates improper connection, flashing green indicates battery greater than 80% charged. If it is a different brand you may be able to find an owners manual on line.
Dan
Dan
My tender has a red, yellow and green light and yellow means that it is charging but the battery is not full yet.
After a while (few hours sometimes) it goes to green and over to it's maintain stage.
This is the one that comes with the Carcoon bike bubble.
If your book says flashing yellow means not charging and you tried it on other batteries with the same outcome I'd say it's a bad charger.
Like a lot here I've got the Deltran BTJ... works like a champ for only 25 bucks.
The one thats not working is the "Super Smart" Battery tender from the MoCo. Even has the HD crest on it. Yellow and green lights only flashing yellow indicates not charging, yellow indicates charging, flashing green indicates battery at 80% and full green indicates that its tending the charge.
I'm leaning towards it being a bad tender as I even touched the clips together and didnt get so much as a spark out of them.......Two years old this unit is. Hard to find good products sometimes......
Thanks to everyone for their thoughts
So under the heading of "do your frigging homework first". I took the seat off the bike and found that the pigtail has a fuse in it that was burnt. This was after I ran out and bought another tender
One 7.5a fuse later and it all works great........
