Black Widow MC lift
I would use this in conjunction with my rear swingarm stand. When the rear is up with that swingarm stand I can sit on it, push it, shake it and that thing is not going anywhere.
I bought the pricey jack off Craigs list from a guy up in Newport News, Va for $200 after the pickup totaled the RG because I knew the bike was going to be up in the air for awhile. But the BMW has both the oil pan and the exhaust beneath the frame rails so pricey one is useless.
This little (3) point might be just the ticket with a few modifications. The pic isn't me but the same bike. All you've got is motor and mufflers to lift against.
There got to be many tricks to store the motorcycle jacks. Mine will roll right under my 4wd pickup. Got a few other items under there.
The 'problem' with tools is just like my old B&W TV. I was happy to have one until I spent some time watching a color set.
Something else may not be obvious, but you can lift a bit with a MC jack off center so one wheel remains on the ground. I did that when messing with some spacers to boost spring tension in my 1987 front forks. Not saying I need to too, but; I always feel more secure lifting anything the absolute minimum needed to do the work.
I've got one, it works great for my bike.
If I'm really cranking on it, it comes with straps to strap the bike to the lift.
It's not going anywhere.
Yeah my brother and I made one of these way back when too. He still has it at his place. They work just fine for what they are intended to do; get a wheel off the ground.
Few pieces of black steel pipe and some rubber to protect the frame where it makes contact. Easy and quick.
LiiT
LiiT
This style of lift has been around for many years. Unfortunatly I don't think it'd work for me. To be safe it takes two people and I don't have any friends. A tool does not HAVE to be expensive to be good. It's value is in it's design and materials and not it's pricetag.
I've had Larin, I have had J&S and I now I have a Pitbull, they all worked. But those videos of guys jumping around on their bike while it's on the jack are a bit deceiving. The jack will remain rock steady as long as the stunts are performed directly between the supports of the jack. Apply ANY pressure to the front or rear of the bike and the bike will rock and the jack will flex. It's done it with my cheap jack and it's done it with both my expensive jacks. If you really want rock steady get a table lift. If you want quick and small footprint get a jack. I like my Pitbull 'cause I got the air assist. And yeah, some are better than others.
The shelf is an idea I stole from another forum member. It holds tools and beer.
I just ordered this lift from Amazon. Looks like it should work okay for lifting my Ultra Limited. I don't need to move it around once it's up so wheels aren't a priority and my Dewalt cordless should run the screw up and down with a socket.
