Black Widow MC lift
#31
I just ordered this lift from Amazon. Looks like it should work okay for lifting my Ultra Limited. I don't need to move it around once it's up so wheels aren't a priority and my Dewalt cordless should run the screw up and down with a socket.
Black Widow Motorcycle Scissor Jack
#32
Also a very small table plate.
#33
I have one of those jacks and it is one of my favorites. Low profile, don't care how low your bike is, that jack will fit underneath it. Fairly wide platform for the bike to set on, but the higher you go the less stable it feels. I raise mine with a 3/4 inch drive ratchet, your DeWalt cordless just aint gonna cut it.
#34
Very stable that way, but not when used as a stand alone by itself.
#35
I have used a small auto type hyd. jack with a block under the kickstand to get the 3 spot tripod when I had no choice but man that's asking Murphy to crap on your day. I use the scissor under them all the time on the table lift, one of the wheels has to be locked down some how or you are flirting with a dumped bike big time.
#36
Speaking of auto jacks placed opposite of the kickstands, you can lift the front wheel of the RG easily high enough to pull the front wheel as long as you brace it for the time it takes to get the tire changed. (Just watch for the wire running down the right frame tube from the alternator to the battery! Pinching it causes lots of sparks...)
#37
#38
I use a blackjack sissor lift from Dereck weaver on my Titan lift table. Table worked great for pulling the primary and transseal out of my dyna.I bought a second sizzor so i could use one front and rear staggerd the oil pan same as the lift arms sit on craftsman and j&s. Dyna is stored on a crafstman red , limited on the table , amd my j&s is sitting empty. I bought the j&s for the limited but the craftsman i reworked it to fit the Dyna. I like the footpedal bleed control on the craftsman better. I dont care for being bent under the bike trying to loosen the bleed valve. I like to stand upright and hold the front brake and bars as it comes down and touches down. i never trust i have the sidestand locked. On the table I raise the sizzor lift up to just hit the bottom frame on bike when i store them on the table. As for raising the sizzor jack, i just use a 8"adjustable wrench, doesnt take much effort, but a socket would be faster. Each has there pro's and cons i guess.
#39
Has anyone used the Black Widow Motorcycle Lift?
http://www.discountramps.com/cruiser-stand/p/BW-37/
It looks like a nice inexpensive alternative to a Sears ATV/MC lift, and easier to store. From the video it looks easy to use and would definitely work for cleaning rims/spokes, but will it lift the front or back high enough to remove a wheel for tire replacement?
#40
j@s jack
The jack never even gets close the the load limit because there's always a wheel on the ground. It will do what its designed to do. He'll do alright with it.
(Now why you think a Harbor Freight $99 POS "jack" is safe for your $16,000 bike is another conversation. That's why GOOD jacks cost closer to $400, (like my J&S Pit Bull for example.)
