Has anybody tried the Go Cruise 2?
Saw this in the latest AMA magazine. Thought about getting one.
http://www.2wheelride.com/GoCruise_t...0control2.html
Received 4,614 Likes
Not even close to a cruise control, though they try to make it sound like one. Just a throttle lock, little more sophisticated (or just more complicated) than most. I've used other throttle locks, work ok in flat states like Illinois and Kansas, but throw some hills in, and your speedometer plays yo-yo. I had a Suzuki that would go from speed limit to over 110 on fairly shallow grades with the throttle locked. I rarely used them when I had them, more effort to keep adjusting the gadget for changing road angles than just using the throttle.
They're awesome on long trips. And when you get into twisties or stop & go traffic, there's no effort required to not use it. I just had the cheap plastic version and even that worked great. But this adjustable unit will work even better.
I tend to put on some miles and wouldn't want to be without some kind of friction lock. There are much better options out there that require throttle modifications & installation. But these are the simplest options that just slip over your grip.
Received 14,139 Likes
Change your grips to the type that has a paddle on the throttle. I did it last month and am very happy.
Try This...
http://www.jpcycles.com/product/5100...none&utm_term=[74945928010%3Aproduct_type_l1%3D%3Dvehicles%20%26% 20parts%26%2Bproduct_type_l2%3D%3Dland%20vehicles% 26%2Bproduct_type_l3%3D%3Dmot&adpos=1o1&creative=4 2616780690&device=c&matchtype=&network=g&gclid=CMW 1pNj1ucICFYlefgodaQ8AXg
Yep, like I said above "The little factory triangle thingy" is in a bad location. Don't like taking eyes off the road to fiddle around with the star wheel.
Maybe for $7 I'll give it try. Probably won't be able to use until April, but thanks for the tip.
